AirOne70 Posté(e) 16 mars 2013 Share Posté(e) 16 mars 2013 Déjà ? Pour quelqu'un qui hiberne.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bungee2 Posté(e) 18 mars 2013 Share Posté(e) 18 mars 2013 Quelle governor et planificateur vous me conseiller. Actuellement je suis sous Intellidemand et FIOPS Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 20 mars 2013 Share Posté(e) 20 mars 2013 perso j'ai mis les configs préconisées pour la batterie et j'en suis ravi (intellidemand avec fréquence max à1.35GHz et -100mV) FauxClock App recommended Settings" CPU Control Max clock - GHz 1.944 GHz (or 1.836 GHz) for performance, 1.512 GHz for battery Min clock - MHz 384 MHz for both CPU Governor - Interactive for performance, Intellidemand for battery mpdecision - Off Snake Charmer - OFF for performance, On for Battery Eco Mode - Off for performance, On for battery Set On Boot - On Voltage Control Set On Boot - Global CPU Voltage - mV intellidemand gov control Up Threshold - 75 for both Boost Frequency - 0 for both Two Phase Freq - 1134000 for both Sampling Rate - 50000 for both Optimal Freq - 1296000 for both Synchro Freq - 756000 for both Set On Boot - On interactive gov control Hispeed Load - 99 Hispeed Freq - 1512000 Timer Rate - 20000 Min Sampling Time - 80000 Set On Boot - On GPU Control GPU Governor - ondemand for both GPU Clock - 487Mhz for performance and 400 Mhz for battery GPU Vsync Toggle - On for both Set On Boot - On for both I/O Scheduler Control I/O Scheduler (eMMC) - FIOPS for both Readhead Size (eMMC) - 2048 for both Set On Boot - On for both Misc Control Dynamic File Sync - On for both TCP Congestion Control - Westwood for both Vibration Control Set On Boot - On for both Vibration Control - 70 for both Screen Color Set On Boot - On for both Factory Presets - LG Presets Color Adjustments - R, G, B 255, 250, 245 Gamma Amp Adjust 0 - R, G, B 13, 20, 22 Gamma Amp Adjust 1 - R, G, B 0, 2, 3 Above is what I use personally. MAY NOT be optimal for all http://forum.xda-dev...823&postcount=2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
puxukrouf Posté(e) 26 mars 2013 Share Posté(e) 26 mars 2013 bonjour a tous excusez moi la question a surement deja ete posée dans les pages d'avant, mais est ce qu'il est possible de rajouter dans la 1ere page la signification des differentes version de kernel -tbu - m -tbm... d'avance merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cyril5689 Posté(e) 26 mars 2013 Share Posté(e) 26 mars 2013 (modifié) Non car celui qui a créé le topic et plein d'autres topic d'ailleurs ne possède plus de N4 donc il y a peu de chance qu'il repasse ici et encore moins qu'il s'investisse sur le forum N4. Modifié 26 mars 2013 par cyril5689 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
vynes Posté(e) 26 mars 2013 Share Posté(e) 26 mars 2013 Il faut quelqu'un qui souhaite reprendre la topic face la demande au créateur du topic et ensuite a un modo. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 27 mars 2013 Share Posté(e) 27 mars 2013 Version 12 dispo. Aucune fonction spéciale d'ajoutée. Juste une mise à jour avec plus de 300 corrections à ce qu'il dit. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
balthazarius Posté(e) 29 mars 2013 Share Posté(e) 29 mars 2013 bonjour a tous excusez moi la question a surement deja ete posée dans les pages d'avant, mais est ce qu'il est possible de rajouter dans la 1ere page la signification des differentes version de kernel -tbu - m -tbm... d'avance merci A défaut de modifier la première page est-il possible que quelqu'un me disent de quoi il sagit parce que j'ai acheté l'applis et je ne sais pas quel version choisir Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 2 avril 2013 Share Posté(e) 2 avril 2013 (modifié) A défaut de modifier la première page est-il possible que quelqu'un me disent de quoi il sagit parce que j'ai acheté l'applis et je ne sais pas quel version choisir Mainline (M) - Fréquences STOCK Turbo Ultimate (TBU) - Turbo Boost à 1.944 GHz Turbo Mainline (TBM) - Turbo Boost à 1.836 GHz source Modifié 2 avril 2013 par BalamWeb Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anfer64 Posté(e) 5 avril 2013 Share Posté(e) 5 avril 2013 Bonsoir, c'est juste pour vous dire qu'il y a des beta de la version 13 dispo avec notamment l'UC jusqu'à 162mhz, cela peut être interresant quand on écoute de la musique écran éteint par exemple. Envoyé depuis mon Nexus 4 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 5 avril 2013 Share Posté(e) 5 avril 2013 Cela peut être pratique, sauf au moment où l'on le déverrouille où il pourra avoir un peu de mal. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cyril5689 Posté(e) 6 avril 2013 Share Posté(e) 6 avril 2013 En effet, tout les dev de kernel s'accordent à dire qu'à moins de 384Mhz lorsque le telephone sort de veille il y a des ralentissements assez voyant(j'imagine qu'à 162Mhz c'est encore plus vrai) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 6 avril 2013 Share Posté(e) 6 avril 2013 je suis actuellement en 162MHz min et je n'ai rien constaté de flagrant .... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anfer64 Posté(e) 6 avril 2013 Share Posté(e) 6 avril 2013 J'avais peur de ce problème aussi mais finalement aucun ralentissement sur le déverrouillage depuis deux jours avec ce kernel.. Envoyé depuis mon Nexus 4 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CoYoTeSnap Posté(e) 12 avril 2013 Share Posté(e) 12 avril 2013 Versions 13 stables disponibles (avec notamment l'UC jusqu'à 162mhz) et mise à jour de l'application FauxClock ces derniers jours. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 15 avril 2013 Share Posté(e) 15 avril 2013 (modifié) la version 14 est maintenant disponible ;) EDIT: ma config CPU: 1.35ghz 162mhz intellidemand Eco Mode Snake Charmer soc: tout activé voltage: -150mV governor: 75 0 1134000 50000 1296000 756000 GPU: ondemand 400mhz IOSCHED: deadline 2048 eMMC MISC: tout activé Modifié 16 avril 2013 par BalamWeb Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 19 avril 2013 Share Posté(e) 19 avril 2013 La 15 beta est disponible. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 19 avril 2013 Share Posté(e) 19 avril 2013 la v015 beta2 pour être précis ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sol invictus Posté(e) 21 avril 2013 Share Posté(e) 21 avril 2013 salut je viens de prend la version 014m du kernel pour tester coupler a la rom xylon et dans les parametre de cpu ca me dis que mon kernel ne supporte pas les paramètre de voltage normal? sous cpu master pareil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 21 avril 2013 Share Posté(e) 21 avril 2013 Utilise Trickster. :) Envoyé depuis mon Nexus 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 22 avril 2013 Share Posté(e) 22 avril 2013 la v015 beta 03 est dispo : Added overall CPU stats (for quad core usage)Enabled Autogrouping Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Toy master Posté(e) 23 avril 2013 Share Posté(e) 23 avril 2013 (modifié) Quelqu'un a noté des problèmes d'instabilité avec le kernel 14 tbu ? Je suis sous CM 10.1 avec ce kernel et les paramètres recommandés et j'ai souvent des redémarrages intempestifs (genre 4 par jours...) C'est génant ! En revanche gros gain sur la batterie ^^ Modifié 23 avril 2013 par Toy master Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 23 avril 2013 Share Posté(e) 23 avril 2013 non pas de reboot pour moi ... j'ai testé la V015b03 mais je ne pouvais plus en envoyer de sms je suis donc revenu vers la v14tbu qui ne pose aucun problème avec un UV de 150mV ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Toy master Posté(e) 23 avril 2013 Share Posté(e) 23 avril 2013 C'est dingue, j'ai aussi pas mal de lags parfois, durant jusqu'à plusieurs dizaines de secondes ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 23 avril 2013 Share Posté(e) 23 avril 2013 (modifié) je n'ai que les 30sec de lag au demarrage du au mod d'amelioration de la sensibilité du tactile ... mais sinon rien ... quels sont tes reglages ? moi : Modifié 23 avril 2013 par BalamWeb Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
