kuan Posté(e) 14 octobre 2016 Auteur Share Posté(e) 14 octobre 2016 Bonjour, mise à jour de la ROM Dev de xiaomi.eu, ainsi que de la Global Dev officielle. xiaomi.eu_multi_HMNote3Pro_6.10.13_v8-6.0.zip https://www.androidfilehost.com/?fid=457095661767101675 Changelog Home screenFix - Part of UI for deleting apps wasn't visible on light backgrounds (10-11)CameraFix - Face frame appeared when recording video in some cases (10-11)SettingsOptimization - Set start and end time for Read mode even when it's off (10-10)Optimization - Separate App lock from Privacy protection password (10-12)Fix - Music could be activated only in the Settings in some cases (10-11)CalendarOptimization - Bigger fonts in month view (10-11)Optimization - Holidays are marked in a more obvious way in the month view (10-11)NotesOptimization - A switch in the settings for showing only quick notes (10-11)SecurityNew - Added automated tasks in Security (10-11)- Added Finnish language- Updated French translation to the Global- Updated Hebrew translation to the Global- Fixed download speed limit (hope for all devices)- Our ROMs were approved by official EU distributor ABC Data to not void warranty for devices sold by them! (Of course, officially unlocked BL and no SuperSU installed) Le fil sur xiaomi.eu https://xiaomi.eu/community/threads/6-10-13.35585/ _______________________________________________________________________________________________ Mise à jour de la ROM Global Dev officielle 6.10.13 Version Recovery 6.10.13 http://bigota.d.miui.com/6.10.13/miui_HMNote3ProGlobal_6.10.13_4869db85f8_6.0.zip Version Fastboot 6.10.13 http://bigota.d.miui.com/6.10.13/kenzo_global_images_6.10.13_20160805.0000.29_6.0_global_b015fadee1.tgz 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
romumu72 Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 (modifié) @jordandroid Effectivement, le site Qualcomm sur les spec du SD650 mentionne bien la charge QC3.0 Par contre sur la page Qualcomm dédiée au QC, il est mentionné uniquement les SD80x, SD617, SD82x, c'est ce qui m'a induit en erreur... En gros le SoC SD650 supporte le QC3.0 mais le RN3P ne le supporte pas, question de licence à payer.... Mais faut un hardware derrière qui suive aussi je suppose... (sauf les custom kernels qui activent le QC2.0.... mais est-ce suffisant pour débloquer le véritable QC2.0??) Je vais faire un post avec des photos prises pendant la charge https://forum.frandroid.com/topic/250122-charge-batterie-avec-fastcharge-qc20/ Modifié 14 octobre 2016 par romumu72 Post crée 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
poulpidou Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 (modifié) 6.10.13 xiaomi.eu installée, il me semble avoir un peu moins de ram au démarrage 1,7Go au lieu de 1,9Go et impossible de récupérer plus, par contre un Antutu à 78912. Modifié 14 octobre 2016 par poulpidou 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rudyjo Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 Salut maj effectué mais depuis quelques jours même avec la rom précédente je n'ai plus de deep sleep... Je ne sais pas pourquoi. Je pensais qu'en faisant la maj ça allé y remédier mais nada. J'ai supprimé et congelé quelques applications au cas où mais toujours pareil mon tél se décharge super vite. Si quelqu'un a une solution ça serait sympa. Merci d'avance. Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
romumu72 Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 (modifié) J'ai moi aussi un problème de deepsleep mais uniquement quand mon tel est allumé depuis longtemps. J'ai pas trouvé la raison mais d'après Wakelock, j'ai un awake de NIpWakelock Le Wifi est désactivé, seule la connexion de données est active La solution que j'ai pour le moment est de redémarrer et là, le deepsleep refonctionne.. Modifié 14 octobre 2016 par romumu72 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
poulpidou Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 (modifié) Pour avoir eu des soucis de deep sleep et m'en être sorti, je testerai en décongelant toutes les apps (sauf Documents) pour repartir de zéro. Franchement j'ai très peu de choses congelées et le deep sleep fonctionne parfaitement avec une autonomie dans la la norme, 2 bonnes journées en usage léger. Ce qui est congelé: Diffusion cellulaire 6.0.1 Documents email Miui V8 (j'utilise Gmail et Outlook) explorateur 1.8.1 (j'utilise FX) Galerie 2.0.0 (j'utilise quickpix) Messages 6.0.1 (j'utilise chompsms) Musique 2.7.7 (j'utilise N7player) Météo 8.1.4 (j'utilise Netatmo et Meteofrance) Navigateur 8.3.1 (Chrome) Testez en repartant des bases, c'est le mieux à faire de mon point de vue. Modifié 14 octobre 2016 par poulpidou Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
malikabyl Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 Mon data quand je met le portable en hotspot WiFi fond à vitesse grand vSachant que j'ai essayer de le mettre en hotspot avec mon ordinateur portable par usb Sur mon ordinateur le logiciel netlimiter m'indique pas de gros débit mais le forfait lui prend un énorme coup 1 go en une heure ou moinsDonc je suis sous la 8.0.2.0 pensez vous que cela vienne de la rom ou du tel ? Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LOLO9393 Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 @malikabyl La conso en hotspot '( tu ne dis pas combien, mais on comprend) est toujours importante. le modem est toujours actif et il aime les mA. Tu peux le voir dans les statistiques batterie ou sont indiqués le total des mAh consommés par chaque intervenant. En data aussi on a les stats dans les données data. Gros piège du hotspot pour les amis: Un Ipad "ami" a fait le téléchargement de la MAJ IoS10 (1.6 Gb) sur mon forfait de 3 Gigas sans me le dire. Solution: faire gaffe. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LOLO9393 Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 @romumu72 Le NlpWakelock se bloque en enlevant la localisation Google avec les réseaux wifi et Network. La solution rester en GPS only. le deep sleep reviendra. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rudyjo Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 Merci à tous. Je viens de faire un test là. (je suis chez moi) donc wifi activé je n'ai pas de deep sleep, par contre si je désactive le wifi, le deep sleep revient. Donc il doit y avoir quelques choses qui tourne en fond genre sauvegarde google ou miui.. Je vais voir si j'arrive a trouvé le coupable. Je vous tiens au courant. Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
malikabyl Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 Le problème c'est que avec mon pc j'ai téléchargé même pas 200mo et j'ai 1 go qui est parti Et on voit bien écrit 1go dans les conso et mon forfait aussi Donc vraiment ya un problème Je n'avais pas se problème avant avec mes téléphone honor Donc je voulais savoir vous qui êtes sur des dev si vous avez ce même constat sinon dites moi votre rom je vais l'installer pour ne plus avoir le problème Envoyé de mon Redmi Note 3 en utilisant TapatalkÉdit j'ai installer lavant dernière dev xiaomi.eu plus de problème Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PetitPoney Posté(e) 14 octobre 2016 Share Posté(e) 14 octobre 2016 Xiaomi.eu Dev 6.10.13 installé avec ke Kernel Radon 2.8. Aucun bug, et de belles améliorations en terme de traduction. Le Fingerprint ne vibre pu lors de son utilisation pour le dévérouillage, pour ma part c'est plaisant.Sent from my Redmi Note 3 Pro *.* 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jose Hidalgo Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 @PetitPoney, chez moi ("vieille" Xiaomi.eu Dev 6.7.21) le fingerprint ne vibre QUE s'il ne reconnaît pas l'empreinte. Autrement le tél se déverrouille parfaitement sans vibration. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Antho03150 Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 bon je reçois mon Note 3 pro mardi donc j'ai une dernière question avant de mettre les mains dans le cambouï/ Je compte le mettre en Gobal Dev 6.9.29. J'aimerais qu'il soit rooter nottament pour utilisation Titanium Backup Sur le tuto déblocage bootloader + installation TWRP + root, il est dit qu'il faut installer une rom xiaomi.eu.......Puis-je juste installer TWRP puis superuser à partir de la Gobal Dev 6-.9.29???? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kuan Posté(e) 15 octobre 2016 Auteur Share Posté(e) 15 octobre 2016 (modifié) Il y a 9 heures, Antho03150 a dit : Sur le tuto déblocage bootloader + installation TWRP + root, il est dit qu'il faut installer une rom xiaomi.eu.......Puis-je juste installer TWRP puis superuser à partir de la Gobal Dev 6-.9.29???? Le titre du chapitre est : Installation du TWRP ZCX + ROM Global ou Xiaomi.eu + Root Tu peux installer le TWRP + root à partir de la ROM Global Dev, aucun souci. Il faut juste que ton RN3P soit déverrouillé. Modifié 15 octobre 2016 par kuan Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
quent13476 Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 Salut, j'ai un bug sur l'avant dernière dev xiaomi.eu, lorsque je suis sur Chrome (ajout photo Facebook) ou autre application je ne peux plus choisir les photos de la galerie, je ne peux qu'avec l' explorateur natif, est ce lié à ces histoires de format sd et MM6 ? MerciSent from my Redmi Note 3 using Forum mobile app Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rudyjo Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 Salut@kuanDis, sur la 1ere page de ton tuto tu montre les applis qu'on peut congelee avec TB, question lors du passage sur miui 8, j'avais bloqué toute la liste que tu as mis mais en redémarrant min tel, celui-ci était bloqué du fait que j'avais congelé compte MI... obligé de tout réinstaller du coup. Ma question est pourrais-tu me dire ce qu'on peut congelé sur miui 8 sans qu'il y ait un problème. MerciEnvoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kuan Posté(e) 15 octobre 2016 Auteur Share Posté(e) 15 octobre 2016 Ca a un peu changé au passage de MIUI 8. J'ai déjà eu ton souci. Il suffisait d'éteindre (en forçant sur Power) et redémarrer une deuxième fois pour ne pas être enquiquiné. Le kenzo est un peu à l'abandon (j'ai pété le lecteur SIM et la pièce détachée trône sur mon bureau depuis quelques jours). C'est suite à l'astuce double SIM + carte SD, à force de l'enlever et de la remettre (kenzo/kate), une toute petite partie de la SIM c'est coincée dans le lecteur, j'ai forcé (comme un âne) et vlan. Plus de réseau ni carte SD. Si j'ai du nouveau pour ta question, je reviendrai sur ce fil pour te le transmettre. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rudyjo Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 Ok super merci. Pas de bol. Moi j'évite au max d'y toucher même si la 4g fait encore parfois des siennes. Juste une autre question, j'ai toujours mon souci de deep sleep même après avoir fait une réinstallation propre. Je sais que c'est à cause du wifi mais je n'arrive pas à trouver le coupable. J'ai même congelé les applis une par une avec TB mais ça ne change rien. Du coup je ne sais pas ce qui cloche. Car quand je désactive le wifi j'ai zéro données qui tournent et en wifi j'ai quasi tout le temps environ 60ko/s. Encore merci pour ton aide si c'est possible.Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PetitPoney Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 @Jose Hidalgo sur la Xiaomi.eu Dev 6.9.29 le fingerprint vibrait que l'empreinte soit bonne ou mauvaise, j'avais omis de le préciser ^^. Et cela m'embêtait un peu j'aime quand c'est silencieux lol. Et la 6.10.13 à ramené ce silence lorsque l'empreinte est bonne, c'est plaisant . Sent from my Redmi Note 3 Pro *.* Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
romumu72 Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 @rudyjoJ'ai eu le soucis du compte mi qui me bloquait le tel... j'avais beau faire et refaire des reboot ca ne changeait rien.Heureusement je fais des backup souvent.Pour le deepsleep, essaye de mettre la localisation sur GPS uniquement. Pour moi ca m'a réglé des soucis à ce niveau.Envoyé de mon iPad en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rudyjo Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 @romumu72,Merci, mais je ne trouve pas l'option GPS uniquement dans les paramètres de location..Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
romumu72 Posté(e) 15 octobre 2016 Share Posté(e) 15 octobre 2016 Paramètres, Google, localisationEnvoyé de mon Redmi Note 3 en utilisant Tapatalk 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
buym0re Posté(e) 16 octobre 2016 Share Posté(e) 16 octobre 2016 Bonjour, je cherche à enlever le root; je le fais dans l'application SuperSU? (Paramètre->"Suppression complète du root") Ou autrement? Je dois au passage mettre à jour mon TWRP 3.0.0.0 -> ZCX je pense Merci ps: Je cherche à refaire marcher l'application myCanal Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
romumu72 Posté(e) 16 octobre 2016 Share Posté(e) 16 octobre 2016 BonjourJ'ai desinstallé titanium backup.J'ai voulu le réinstaller et là j'ai une erreur... Impossible de l'installer même avec l'apk et même avec une version antérieure... Par contre mycanal fonctionne sans soucis...Envoyé de mon Redmi Note 3 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
