Waze : GPS Communautaire (LIENS PAGE 1)
ALF1998
We’re rolling out the latest Android Waze Beta v.4.0.9.1.
Beta Notes:
  • Improved sensitivity when changing zoom levels
  • Editors Map Scheme is now available
  • Landscape mode - fixed car position
  • Landscape mode - removed current street name label
  • Fixed an issue where users were unable to delete items from the navigation list
  • Search results should now show "Time off route" correctly
  • Fixed the bug where Gas Prices reporting was missing from the Reports Menu.
  • Searching for Gas Stations should now work correctly
  • Fixed a Calendar Events bug where push notifications would open the map
  • Confirm address push of calendar event bug is fixed
  • Slow down detected inline notifications bug is fixed
  • Crash and stability fixes
Known issues:
  • After upgrading, the selected voice prompt might get reset to the default voice
  • As part of our effort to improve the communication between the Beta testers and the Waze team, we’ve created this post in Centercode newwindow.pngThis post is relevant for iOS and Android beta testers and we will update it with our ongoing progress in every few weeks.
Please keep in mind that beta versions released on Center Code are INTERNAL ONLY.
We trust you not to share this content with anyone. The Waze beta group exists thanks to your cooperation and discretion.
We look forward to seeing your feedback via Centercode, you may use this forum thread newwindow.png to post anything related to this version!
Waze Beta Team
y a toujours pas la fonction du calcul de l heure de depart pour arriver a une heure precise?
En même temps on peut se mettre à la place des devs, retrouver leurs versions sur t411, c'était peut être pas le but. ....
Je suis d'accord mais bon si tu mets quelque à disposition sur le net, tu ne pourras pas empêcher les autres façons de partager.
De toutes façons, internet et confidentiel ce n'est pas fait pour aller ensemble...
mouais... on verra bien ce qui se passe par la suite...
Vos histoires de trains, de gares, de retards, d'erreurs, ressemblent fortement à un groupement élitiste...
En tant que "lambda" inculte, j'attendrai les mises à jour quand elles seront disponibles au grand public sans avoir besoin de devoir "pleurnicher" pour quelque chose...
Le partage est une action sans contre partie...
Regarde quelques posts avant principalement ceux d'ALF , tu comprendras.
Oui mais cela ne donne pas trop envie de partager.
Quand tu vois certains commentaires.
Les personnes qui mettent à disposition ne prennent pas souvent la peine de mettre les sources.
Je ne pense pas que hypnotik ne partage pas sa version car il est saoule de se retrouver sur t411, mais plutôt par crainte de sortir une version avec un hack de signature. Donc vous emballez pas. :-)
Enfin je peux me tromper, je suis pas dans la tête des gens.
C'est le problème d'internet, les gars on est en 2016... si tu mets tes fesses en photo sur fesse bouc, c'est normal qu'elles se retrouvent au panama pour servir de cible dans un bar à fléchettes...
Malheureusement, des "modifications" du type réalisé sur waze sont sur t411, majax, lolo, warez et cie (auto censure des noms)... C'est la loi du partage et du monde libre d'internet... Pour moi c'est plus un western spaghetti mais bon...
il y a aussi du bon dans le net, mais y'a également beaucoup voir même énormément de mauvais et de comportements plus que discutable.
A ceux qui font avancer l'histoire, je dis BRAVO, la seule récompense est mon respect (c'est pas grand chose vu mon pseudo :) ), aux autres parasites gratteurs, fouineurs et autres... je leur glisse un truc dans un orifice dont je tairais le nom !!  :emo_im_money_mouth:
  • Like 2
Toggelis .Waze Editor pour Waze 3
Je viens de constater que pour avoir les voies (autoroutes, voies rapides etc)  bien séparées (œuvre de Tamariz33) avec la 398auV5b+,  les modifs de couleur des cartes avec TWE doivent être baptisées Map Editor (et prendre dans "Affichage" de waze "Les éditeurs de Carte").
Par contre j'utilise TWE 1.2.3.1.p. (Version pour Waze 3) et Google s'acharne à me faire des mises à jour en me collant TWE pour Waze 4.
Comment interdire la mise à jour de TWE ??
Merci de votre aide
Modifié par Invité
Je trouve dommage que sur cette nouvelle version on ait pas la possibilité de voir tous les signalements autour de nous comme sur les versions précédentes. A part bien sûr si je ne vois pas où activer cette option...
Waze a souhaité une version épurée donc tout est passé à la moulinette avec la purée  :P
Merci de votre aide
Dans le play store, il faut cliquer sur les 3 traits à gauche de la barre de recherche, puis paramètres et tu actives les options désirées
Grand merci
Mais oui, mais c'est bien sûr .
Je le savais, plus exactement je l'ai su,mais je n'arrivais plus à trouver où.
Grand merci
c pas plutôt dans paramètres -> application -> choisir l application et décocher afficher notification. Sinon tu n auras plus aucune maj de toutes tes applications.
j'aurai préféré que la photo de mes fesses finisse dans un club de bouliste pour servir de Fanny... c'est quand même plus agréable de se faire embrasser le derrière!!! :P
  • Like 2
je pense que tu parlais de radar france de sygic avec une source Here en payant et Osm en gratuit.
Edit : c'est peut etre navmeter enfin de compte, je sais plus comme je n'utilise ni l'un ni l'autre
effectivement je faisais aussi l'amalgame. ......on en est où avec radars France ?? Tu l'avais acheté alf il me semble ??
Il y a toujours possibilité de le faire retirer...
Eh bien avec ce genre de commentaires on est pas prêt d'avoir une version modifiée...
Sinon pour les nouveaux éditeurs, merci de faire attention aux flèches rouges lors de vos mise à jour ;)
C'est bien beau d'avoir l'affichage des limitation mais si c'est au détriment du guidage, il ne vaut mieux rien faire ;)
Il faut lire le wiki avant de se lancer.
Envoyé de mon SM-G920F en utilisant Tapatalk
  • Like 3
La notification c'est que tu ne seras pas prévenu.
Je préfère gérer la mise à jour de mes applications, c'est mon avis.
Comme j'utilise Xprivacy il faut que je valide les options pour chaque application.
Je préfère que mes fesses restent dans mon boxer.
Vous êtes maso ou quoi.
Maintenant ce n'est pas du GPS tout ça.
Je te promets que je fais attention.
Y a encore du boulot  :mad:
D13 au départ
A l'arrivée
J'ai perdu Waze en chemin  :emo_im_undecided:
C'est quoi ton impression sur Velo....
Modifié par herve-91
Si très bien, je voulais faire de la pub pour ma région :) pour l URL de leunammr
Non, très bien ton URL. J t'en remercie
Ah, tu parlais des changelogs, j t'en remercie également. Mais elles sont disponible sur apkmirror. Merci comme même. Tu peux continuer.
Note : je redige sur mon smartphone pas très confortable désolé pour la "méprise" :)
Modifié par strange76
