Meelouw Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 (modifié) Lien de la version VO : Clique ICI Détails du kernel : Révéler le contenu masqué * THIS IS ONLY FOR 4.0.3 or 4.0.4. If you ask if it works on older roms I will shoot you * Overclock up to 1344mhz * Custom Voltage Control from Ezekeel * Completely updated CRC32 library that is used for a lot of core functionaties of the system * CFS scheduler tweaked for the best user experience * Stock GPU clock - reason(http://forum.xda-dev....postcount=4731) * Simple IO scheduler by default * Ext4 tweaked and patched up for performance * I/O writeback backported from 3.2 * SLUB memory allocator as default * USB HOST enabled * TUN enabled * ColorControl from Ezekeel Command: echo "-10 0 -2" /sys/class/misc/colorcontrol/v1_offsets this is just an example, values range between -255 and 255. If you want the values to stick on reboot create an init.d script or use my app * Hotplug mod added. Works independently of the governor. Shuts down cpu1 on screen_off and wakes it up again on screen_on To disable: echo 0 > /sys/module/omap2plus_cpufreq/parameters/generic_hotplug To enable: echo 1 > /sys/module/omap2plus_cpufreq/parameters/generic_hotplug * Custom ramdisk included with proper ext4 mounts for performance * Kernel config stripped out from debug shit (only logcat and dmesg stayed) * A lot more stuff that can be seen on my repo /sys/class/misc/colorcontrol/multiplier color multiplier triple (default = factory settings; set with 'echo "2004318071 2004318071 2004318071" > multiplier' for example; if the safety is enabled the color multipliers cannot be raised above the factory settings) Changelog :Stable M3 Révéler le contenu masqué This is the perfected version of the last 35 days of testing of roughly 1 nightly build a day. The most important changes from Milestone 2 are: * Merged 4.0.4 kernel patches from Google (IMM76D and IMM76I) * Data dropouts is fixed * Interactive Governor patched up to be in line to android-3.0 branch * Hotplug governor added and tweaked for stability * Merged a lot of patches from omapzoom.org for battery and performance improvements in our OMAP4 board drivers * Hotplug_mod renamed to Generic Hotplug and changed paths to: /sys/module/omap2plus_cpufreq/parameters/generic_hotplug * Added BLX from Ezekeel. The default value is 96. Path: /sys/kernel/fast_charge/force_fast_charge * Reduced VAUX3 and VUSIM voltages for more screen_on time at the end of the day * Simple IO scheduler added and made default * EXT4 patches from 3.0.2X kernel.org patch * Lots of small tweaks and improvements that are available on my bitbucket git repository Pré-Requis :Avoir un GN rooté EN 4.0.3 minimumAvoir le recovery d'installéInstallation :Voir le tuto de luigiTéléchargement :Lien de téléchargement de la dernière NightlyLien de la dernière version stableExplication du réglage du kernel et une aide /!\ A faire à vos risques et périls, personne ne pourra être tenu responsable en cas de mauvaises manipulations de votre part.Remerciement : Citation FranciscofrancoIl existe aussi une application pour télécharger directement le kernel sur le téléphone, le régler et voir les changelogs ! (ICI) Modifié 19 mai 2012 par Meel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
subout Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Pour moi c'est le kernel que j'utilise et franchement il déchire..... Couplet à la ROM AOPK de Kang... +++ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yuri Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 c'est celui pour la 403 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 uniquement pour la 4.0.3 ^^ je vais rajouter pour pas que des gens se trompent Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DarkGruf Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 (modifié) Je suis sous ce kernel depuis hier et c'est parfait. Il passe sous la modaco qui bien qu'étant une 402 utilise assez d'éléments de la 403 pour être compatible. Par rapport au kernel "d'origine" de la modaco celui de Franco donne un téléphone plus fluide en particulier au déverrouillage tout en étant aussi économe sur la batterie. Ce qu'il nous dit ici : " During screen_on frequency is ramped up to the maximum frequency and stays there for 5secs. This will get rid of the lag when unlocking the screen and makes sure the device wakes up propely" n'est donc pas que du "marketing" mais est bien réel. Modifié 4 janvier 2012 par DarkGruf Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sian391 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Je test . B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 mieux par rapport au JDKERNEL 3.0.14 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 je sais pas, je l'ai installer que hier je le test, et pour l'instant j'en suis content ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 je vais la tester. Suis un peu déçu par l'autonomie de la batterie avec la jdkernel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Installé !! Quadrant : 2849 Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sian391 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 tu sais les test quadrant ne valent trop rien dire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 oui je sais, mais par comparaison avec le JDKernel ou j'obtenais péniblement 2100, il y a quand même une différence assez notoire. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 justement, tu peux pas être sur que francisco n'ai pas fait en sorte de gonfler les scores ce qui est assez facile ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 gonfler les scores de Quadrant? non franchement, je viens de refaire le test, le file system read and database write sont vraiment plus rapides. Idem pour le défilement vidéo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 je dis pas qu'il l'a forcemment fait, mais je veux juste dire que c'possible. Après oui il a l'air plus fluide et justement sa se voit plus à l'utilisation :) quadrant donne une indication c'sur mais on doit prendre le résultat avec des pincettes malgré tout Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DarkGruf Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 (modifié) Attention la version 9 était buggée il y a un update en 9.1 Au passage pour soutenir l'auteur si on aime ce kernel on peut acheter son appli à 1€ qui permet d'être au courant des mises à jour et de télécharger directement le dernier cru : https://market.andro...m.franco.kernel Le 04/01/2012 à 17:19, Meel a dit : justement, tu peux pas être sur que francisco n'ai pas fait en sorte de gonfler les scores ce qui est assez facile ^^ Tu as lu sa signature sa signature sur xda ? Modifié 4 janvier 2012 par DarkGruf Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 Je viens de le faire. Bref ça change pas mon message d'après ou je dis pas qu'il la fait. Surtout que je disais ça de manière générale, il y sont que lui qui fait des kernel et que d'autre peuvent le faire. Perso je test la fluidité par l'utilisation et non par un test de chiffre Envoyé depuis mon Sony Tablet S avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Meel, je suis totalement d'accord avec toi sur ce point. J'ai juste fait le test comme je l'avais fait quand j'ai installé le JDKernel et avec le kernel d'origine. La fluidité de l'appareil reste la chose la plus importante. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 4 janvier 2012 Auteur Share Posté(e) 4 janvier 2012 Ha je critique pas ton test j'explique surtout mon avis ^^ après j'attaque personne Envoyé depuis mon Sony Tablet S avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DarkGruf Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 (modifié) Toutafé de ton avis Meel, surtout pour un développeur de kernel ça doit être particulièrement simple de leurrer un benchmark. Mais bon sa signature je la trouve tout de même excellente :) pour les anglophobes je tente une traduction : However, if you put any trust in Quadrant scores you could use them to prove that dancing naked for 5 minutes in your garden affects device performance. By Chainfire Quoi qu'il en soit, si vous avez la moindre confiance dans les scores de Quadrant vous pouvez les utiliser pour prouver que danser cinq minutes tout nu sous la pluie dans votre jardin a une influence sur les performances de votre appareil. Par Chainfire Modifié 4 janvier 2012 par DarkGruf Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Juste au cas où: androtransfer.com/franciscofranco/Galaxy%20Nexus/ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 5 janvier 2012 Auteur Share Posté(e) 5 janvier 2012 maj 9.2 http://androtransfer.com/franciscofranco/Galaxy%20Nexus/ j'éditerai plus tard Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chip77 Posté(e) 5 janvier 2012 Share Posté(e) 5 janvier 2012 5th January - nightly #9.2 * Screen_on function cleaned up - hoping for the supposed extra 1 or 2 secs of screen on to be fixed * Removed some debug from the config 5 janvier - nightly #9.2 * allumage écran - j'espère que les 1ou 2 secondes superflus lors de l'allumage de l'écran ont été supprimées * Quelques suppressions dans le mode debug de la config Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
papi11on Posté(e) 5 janvier 2012 Share Posté(e) 5 janvier 2012 Possible de le flasher avec une Revo HD 2.1.2 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meelouw Posté(e) 5 janvier 2012 Auteur Share Posté(e) 5 janvier 2012 si elle est en 4.0.3 oui mais je crois pas qu'elle y soit Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
